[ARM] Implement ARM Core M0 as a testchip and verification using UVM
ApTuPr
Junior Member level 1
Hi Folks,
I hope you all are fine. I need your extensive help. I am going to work on a project to Implement ARM Core M0 as a test-chip and verify it using UVM. Can you please tell me how to initiate and the important resources I might need? Also, how to write its uvm code?
Waiting for a reply soon!!
Thanks
Sorry to disappoint you with my answer.....
But this is a forum where you post a SPECIFIC PROBLEM with suppotting data in various formats (depending on the problem). Based on how nicely you have formulated the question and problem description, you will get SUPPORT, THAT WILL HELP YOU TO SOLVE THE PROBLEM. One thread, one problem...that's it! Another problem, another thread, and so on....
What you are asking for is like project consultancy which is most probably out-of-scope work for this forum.
If this is an academic project, please consult your professor/guide for details on resources required to start this work.
Thanks so much dpaul. Will definitely look into it. Thanks for your help
