impedance matching with Zg=1-j0.8 and load Zl=1.
sundarmeenakshi
Full Member level 3
Full Member level 3
impedance matching doubt
i want to match sourse with Zg=1-j0.8 with load Zl=1.
which method is best?
1. connect one +j0.8 term between Zg and Zl
2.use LC matching but we need two elements.(some values)
Which one is best?first or second why?
Re: impedance matching doubt
Hi
Well the first option is easy, but you have to consider your bandwidth.
Higher bandwidth require more elements and using more than 3 elements can control your Q.
Regards
tyassin said:
Hi
Regards
in terms of power there is any difference?
At one frequency there is no theoretical difference. However, there is the parasitic losses of the series element to cancel the reactive part.
my question is power transferred to the load is same or not?
Transferred power with just the series inductor should be slightly higher than with a pi network. This is because the circulating current in the pi will be larger than the just inductor situation and the power loss in the inductor's parasitic resistance will be lower.
so single inductor circuit is better only one element we are using power delivered to the load is also high.(i think it should be same both cases we are satisfying maximum power transfer theorem
In the mathematical world all methods of matching are equally effective. In the physical world, inductors come with a series resistance.
I agree with tyassin and also you should consider what kind of frequency-band designing for.
check out the smith chart after trying to match them if there is a dot on centre then impedance is matched try out by varying length and try to design it on single frequency.
