Nassimovitch
Junior Member level 1
good morning dears
need for emergency help !!!!!
I want to reach out an impedance matching between microstrip line (characterisitc imedance Zo) and rectangular waveguide ,actually is a SIW,
through a microstrip step discontinuity transition with characterisitc imedance Z1, (see the attached figure), actually I spend a lot of my time without being able to find the appropriate Z1 impedance. so I have some questions and I will be thankfull if you answear me :
1- For impedance matching, I take input impedance of rectangular waveguide as a load impedance , is this correct or not ?
2- To calculate input impedance of rectangular waveguide using hfss, I use the expression :
Zin = Z11-(Z12*Z21/(Z22+ZL)) where ZL=50 Ohm. is this correct ? if not is there any method to find Zin ?
