impedance matching transformer
masudasim
Junior Member level 1
Hi all
I have a QSC audio amplifier (RMX 4050HD) and an acoustic transducer having input impedance of approx 180 oham at resonant frequency. QSC amplifier can provide about 2000 watt to 2 oham load (speaker) . If i directly connect transducer to amplifier, i only get 50-60 watt output. I require atleast 600-700 watt power so i need a matching transformer (probably step-up transformer) b/w transducer and amplifier.
Can any one kindly suggest charecteristic parameters (e.g. winding ,core , insulation etc) of transformer most suitable for my application?
Is there any software availavle for design of such transformers?Most software available on net are for RF matching transformers
Note:My operational frequency band is about 3-5 KHz
Best Regards
You'll get the fourfold output power by operating the amplifier in bridge instead of parallel mono mode. For higher power, a step-up transformer is required. You can e.g. dimension the transformer for a minimal frequency of 1 kHz, resulting in a factor 20 reduction of windings count compared to 50 Hz and respectively higher power with a small core. According to the high output voltage of the transfomer, a layer insulation is suggested. For audio applications, tranformer calculation is basically similar to a low frequency (mains) transformers, there have been various contributions at edaboard related to it, see e.g. https://www.edaboard.com/threads/214708/
Thanks for your helρ. As i have to oρerate two transducers from single ρoweramlifier, i have to use it in parallel mono mode.
Can you kindly exρlain the relation bw winding count and frequency and also with core size
Best Regards
The relation between winding count, frequency and core cross section is set by the maximum flux for a given magnetic material. Windings per volt is inversely proportional to frequency and cross section. Increasing losses demand a slightly lower flux at higher frequency.
