neazoi
Advanced Member level 6
Hello I design a microwave transceiver using a double balanced 50ohm passive diode mixer. I need to drive this mixer from the sound blaster of a PC.
As far as I know a typical sound blaster output impedance on the green plug is about 32 ohm and the input impedance of the microphone input is about 600 ohm.
For the RX, I have found an amplifier that has a 50ohm input and around 500 ohm output but what about the TX? can I match the 32 ohm to the 50 ohm of the mixer by just connecting a 50ohm resistor in series, between the sound blaster output and the mixer port?
