suria3
Full Member level 5
Dear People,
I'm doing research on impdeance matching for chip interface. As we know, in order to have have maximum power transfer without any reflection or distortion on the signaL path, the driver and the receiver must match the 50ohms line impedance. There are a few types ofinterfaces available in the market like LVDS, CML,PECL and etc. I have some confusions when come to the impedance matching when use these configuration.
Question:-
I'm attaching a few diagrams of the mentioned interface termination. As we know , in order to match the line impedance, the total output impdeance at the driver is to be 50ohms as well. Is this meant that the load at the output of the stage need to be 50ohms. Let say i have a diff amp as in the diagram, which have a load of 1000ohm, and in the end once i do the ac small signal analysis, i will have the output impedance of 1000ohms with assumption i ignore the large collector-emmitter resistor. So, if this is the case, how can i have the output impedance to be 50 ohms.
If, at the output, i just add 50ohms load to ground in order to match 50ohms line impedance, dont the circuit will look like this 50ohms in parallel with 1000ohms?
I hope, people in this forum will explain to me, how actually the impedance matching is calculated and it is terminated in the right way. Your cooperation is very much appreciated.
Is this 50ohms matching at the receiver and driver is not included the load resistance looking into the circuit itself...please advise.
Thanks in advance,
SURIA3.
Question:-
Thanks in advance,
SURIA3.
