Impedance Calculation
mrblueblue1234
Junior Member level 1
In the attached image I am showing a voltage divider with the values of 50M (fixed) , 4.7k (fixed) and an unknown impedance Z.
Is it possible to calculate the value Z only using Vin, 50M and the 4.7k without using Vout directly?
I am looking for a simplified equation for Z that doesn't explicitly need Vout.
For this same application I saw a formula that didn't include Vout here so I was curious on the details.
Thank you for your thoughts.
Vout is a percentage of Vin. The formula is:
(4700 + Z)
divided by
(50M + 4700 + Z)
To find Z, make the above formula equal to your desired percentage, then solve for Z algebraically.
Using Brad's formula works for pure ohmic values.
But for true impedances (and this is how I understand your question) you need graphic (vector) solution.
I assume even with the value of Vout it is not possible to calculate Z as an unknown impedance.
(Combination of R L C, or R C, or R L, or L C)
Klaus
Added:
Maybe with:
* Vin, sinewave, known amplitude, known frequency
* Vout, amplitude, phase shift
* and the knwledge it is no R LC impedance
...you may be able to calculate Z
Thanks for the posts everyone. A follow-up to what BradtheRad posted.
My follow-up question is that if Vout is a percentage of Vin how do I know what this percentage is? Do you mean the transfer function, i.e. Vout / Vin ?
For example, if I capture some data for Vin and Vout should the ratio of Vout/Vin always been the same?
This is a simple case but I was not make sure I am following you.
In this case the ratio would be Vout/Vin that is ~0.091
If one of the resistors was changed I should be able to solve for this because I know the ratio and the other resistor value. Right?
Thanks.
Now it's a completely different situation:
* only two resistors
* no complex impedance
You now have a simple resistive voltage divider.
The formula can be found million times in the internet.
Klaus
