Hamzeh60
Newbie
I've designed a video processing system. The camera is based on an On-semi image sensor, plus SER and DES chips, and an FPGA for processing.
There is a problem which I struggle with it for a while. In too dark conditions, there is a very heavy horizontal white line noise on the screen (I know such noise exist in image sensor theory, but the problem is the level of noise is very high.).
- I know the source of noise is not the SER/DES/CSI reader/FPGA... because using the sensor settings, I can make a fully black output which is clearly visible at the display, without any noise.
- using "fade-to-black" and smililar settings, I can make the video darker to "hide" the noise, but can't remove it.
- noise does not exist in light conditions. it is a dark noise.
- I am very suspicious to the sensor PCB itself.
did anyone have such a experience?
