I'm looking for VB progrimming with RS232
J_expoler2
Member level 4
Member level 4
Hi
using Events on comm
thank
hai,
install msdn.the code is avilable in vb/sample dir
under mscomm dir
anyway if you are ging to do a real serious job don't use vb...
1. control and time response is not so deterministic
2. if you put the vb program in a "complex language system" (chinese for example) it will not work (or to make it works you have to do bad jobs a spend a lot of time)
bye
This may help you or try www.planetsourcecode.com
Private Sub acomm_OnComm()
Select Case acomm.CommEvent
' Handle each event or error by placing
' Errors
Case comEventBreak ' A Break was received.
Case comEventCDTO ' CD (RLSD) Timeout.
Case comEventCTSTO ' CTS Timeout.
Case comEventDSRTO ' DSR Timeout.
Case comEventFrame ' Framing Error.
Case comEventOverrun ' Data Lost.
Case comEventRxOver ' Receive buffer overflow.
Case comEventRxParity ' Parity Error.
Case comEventTxFull ' Transmit buffer full.
Case comEventDCB ' Unexpected error retrieving DCB
' Events
Case comEvCD ' Change in the CD line.
Case comEvCTS ' Change in the CTS line.
Case comEvDSR ' Change in the DSR line.
Case comEvRing ' Change in the Ring Indicator.
Case comEvReceive ' Received RThreshold # of chars.
Case comEvSend ' There are SThreshold number of characters in the transmit buffer.
Case comEvEOF ' An EOF character was found in the input stream.
End Select
End Sub
