C-Man said:It is the entire firmware.
I have also modifyed an "old" ICD1 with 18F252 10 MHZ crystal and the extracted firmware. Programmed it into the 18F252 and it is an ICD-S40 now
Please note that there are two versions one for PIC16 and one for PIC18 depends which chips xou want to program with the ICD later ...
best regards
hugo said:C-Man said:It is the entire firmware.
best regards
Have you been able to use the bootloader for the ICD1 with 18F252 ?
preatorian said:Hi to all again,
I'll try that, C-man. Have you tried to upgrade the firmware through the icd.exe? I've tried with the 16f876A with modified bootloader but it gives some errors...
regards
Added after 59 minutes:
I had a look at the *.fw file. There are two versions of the s-40 firmware. I think that both are for 16 AND 18 series, but the firmware types are different: 0x60 and 0xa0. What is the difference?
regards
pirev said:Hi C-Man,
I have my cloning of ICD-1, modyfied to ICD-S40, but I can't upgrade firmware with icd.exe, after 18F252 has programmed with stand alone programer. I think that in extracted firmware from *.fw is missing a bootloader. Can you share your hex file for 18F252, please ?
best regards,
pirev@abv.bg
Hi, C-Man, in *.fw file is missing a bootloader. If you have original working ICD-S20 or ICD-S40 unit from CCS there is no problem, but if you make own ICD-S20 or ICD-S40 ( using old MicroChip ICD-1 or some cloning of ICD-1 ) and use firmware from *.fw file, then your ICD-Sxx is unable to update firmware through ICD Control Program. Firmware can be updated only with stand alone programmer.C-Man said:pirev said:Hi C-Man,
best regards,
pirev@abv.bg
there is nothing missing in the firmware files.
I am afraid I can not upload the code here because I do not want to violate copyright of CCS.
Are you sure you have extracted the correct file??
You could pm me your file and I will check it ...
best regards
