iip3 for diff mixer using ads
samaneh_mahmoudian
Newbie level 5
Newbie level 5
hi , could you help me, how i can simulate iip3 for a diffrential mixer?
There are six terminals(RFinp, RFinm, LOinp, LOinm, IFinp, IFinm)
So there are 36 characteristics regarding both physical ports and driving schemes(Diffrential and Common).
What characteristics do you have to evaluate ?
If only simple diff-diff-diff characteristics is required, use ideal balun for RF, LO and IF.
https://www.designers-guide.org/Analysis/diff-sp.pdf
https://www.designers-guide.org/Analysis/diff.pdf
Thanx for your attention...
I used 3 baluns for (LO,RF,IF)
But I have a problem for simulate ... in display window the result has a lot of distortion for fundamental and 3-order Vif.
Thank you so much...It is a gilbert cell mixrer...I used 3 balun for LO,RF and IF ...but I have a problem in simulation...the result of fundamental and 3-order of Vif is not good..it has got distortion
I couldn't understand 3 tones for mixer.How i should write ipo_lower and ipo_upper for mixer? could you tell me?
It's not a distortion, your Mixer is simply not working.Have you set-up properly HB controller ?? RF Frequency,LO Frequency and IF Frequency ??
I think something is missing in HB controller.
I checked it...it was wrong...I gave my answer ...thank u a lot!
iip2 measurment in diff mixer using ads
hi...
could u help me, how can i simulate iip2 for a diff mixer by ads?
Thanx
