[SOLVED] Ignoring code during synthesis using design_compiler
daem
Newbie
Newbie level 2
Hi all!
Is there a way to ignore VHDL code during synthesis while using design_compiler? I'd want to add code to my design only for simulation purposes, and not have the synthesizer deal with it.
I have seen that some other synthesizers support this syntax:
-- synthesis translate_off
Code goes here
-- synthesis translate_on
But I have not been able to find if that is supported in the design_compiler docs (I'd imagine not).
At the end I did try
−−synthesis translate off
and it worked, so I guess never assume anything with these tools.
I also tried all of @ThisIsNotSam's suggestions, and all of them worked, so thanks for the reply!
