mikepicco
I am building a switching circuit using an IGBT. What I have is a 120VAC circuit that goes through a full-wave bridge rectifier. An IGBT (collector - emitter) is placed between the + and - terminals of the rectifier. I am using a 10 Ohm gate resistor with a 12VDC source for the gate. The turn off voltage is 0V. To test the circuit I am simply tying the gate (through the gate resistor) to either +12VDC or gnd (0V) with a double throw switch. The IGBT always is in a conductive state regardless of the gate input. Later it is my intention to switch the gate at 120Hz (very slow). Any ideas why the IGBT will not "turn off"?
Thanks,
Mike
Thanks,
Mike
