IGBT replacement help
Gaber Mohamed Boraey
Full Member level 5
Full Member level 5
hello everyone
can i use the IGBT number MM75G5U65BX, instead of P75V65 SDS1?
attached the datasheets, please look and give me your experience
the ratings for ampere and voltage are the same, but the switching time little different, are they cross reference for eachother?
these differences are a big issue if replaced with each-other or it is normal and within range
  • MM75G5U65BX.PDF
  • 171584704518082wwx9.pdf
LaTeX Commands Quick-Menu:
