IGBT modules + IR2110 + arduino
ricperes
Junior Member level 2
IR2110 driver + arduino
Hello , I have tried to control a full-bridge inverter. So i made my SPWM signals through Arduino like this code! I want to use a IR2110 driver, but I have seen many schematics to do this, I already use this : https://tahmidmc.blogspot.pt/2013/01/using-high-low-side-driver-ir2110-with.html , I used exactly the same values of C and R. In sum , you can give me a feedback , if this Schematic is good, or if my code is correct please? Thanks
void loop() {
  for (t = 0; t < 10; t = t + 0.001) {
    Uref = sin(2 * PI * 50 * t); // sin reference
    notref = -1 * sin(2 * PI * 50 * t); // negative sin reference
    carrier = ((2 / PI) * asin(sin(2 * PI * 3000 * t))); //triangular wave
    if (Uref >= carrier) {
      analogWrite(10, 0);
      delayMicroseconds(25);
      analogWrite(11, 255);
    } else {
      analogWrite(11, 0);
      analogWrite(10, 255);
    if (notref >= carrier) {
      analogWrite(3, 0);
      analogWrite(9, 255);
    } else {
      analogWrite(9, 0);
      analogWrite(3, 255);
Re: IR2110 driver + arduino
Hello, what i have tried to do is this:
https://e2e.ti.com/resized-image/__...erver-discussions-components-files/171/f1.JPG
So Uref and -Uref are the sinusoidal waves and the carrier is the triangular wave
You did not informed exctly with which of those schematic were made your experiments.
Moreover, this piece of code do not make sense: You are getting the inverse of the same function, f-1(f(t)):
I'm not experienced in Arduino, but why don't you simply make something like this, instead ?
carrier = (2 / PI) * 3000 * t  ; //triangular wave
In addition, your code apparently put some value at the analog output of the Arduino board, buy in order to achieve your intent with the IR2110 driver, you should deal with some PWM output, digital of course.
Your original question concerned about the suited circuit for this task, and now you added an image that even answered my question.
Sorry , but i don't understant .. you suggest to change the triangular wave
by this
... ?? This is a straight , i want a triangular wave... Sorry my confusion ...
Hello, i need some help please, What I do is create PWM signal on Arduino and through the IR2110 driver, control this IGBT module that is in the picture, I have tried to use this schematic but not sure I will give good results, someone tried it?
Sorry , but i don't understant ...
You should be aware that the function y=arcsin(sin(x)) is the samething of y=x.
Certainly, but as mentioned above, will not work with the code you posted above due to the reasons already mentioned, quoted below:
your code apparently put some value at the analog output of the Arduino board, but in order to achieve your intent with the IR2110 driver, you should deal with some PWM output, digital of course.
You have to replace the function analogWrite() by some API of Arduino which is able to generate PWM outputs.
I replaced the analogWrite by DigitalWrite. but you said that y=arcsin(sin(x)) is the samething of y=x., but when i plot a graphic in matlab for example, the results are different
How different were the results ?
Which code you made for that simulation ?
void loop() {
    carrier = ((2 / PI) * asin(sin(2 * PI * 10000 * t)));
      digitalWrite(10, LOW);
      delayMicroseconds(50);
      digitalWrite(11, HIGH);
    } else {
      digitalWrite(11, LOW);
      digitalWrite(10, HIGH);
      digitalWrite(3, LOW);
      digitalWrite(9, HIGH);
    } else {
      digitalWrite(9, LOW);
      digitalWrite(3, HIGH);
just that , The first arm is ok! But the second arm not
Of course the results will be different. asin(x) is a multiple value function whereas matlab (I use octave) returns the principal value.
Your output will be a triangular wave. y=x and y=asin(sin(x)) are not really same.
Let us take a careful look. y=x is a straight line extended on both sides. It has a slope of 1.
sin(x) is both bounded above and below +/-1. asin(x) is having an infinite number of solutions but the principal value is bounded +/- pi/2. So we cannot have y outside +/-1. QED
Code is really simple but the language is tough.
thanks
So what is the best way to implement a SPWM in arduino?
You are absolutely right, in fact y=x and y=asin(sin(x)) will not produce the same result, unless within the range [-PI/1...PI/2]. Anyway, the point I wished to emphasize is that the code is not optimized the fashion as it was made, and a lot of processing resource of the core may be wasted using the actual implementation arcsin(sin(. The function he wants to get is purely linear, and by using a simple logic could control the quadrant of the triangular waveform.
