kornjace
Newbie level 3
Hi, I' ve constructed an DC-DC converter with IRG4PC30KD. I'm driving it with a PWM from a pic at 20 kHz. (attacment 1) what I tried to achive was do dim a 12V DC lamp. now, on the outside, it's seem all fine, becouse i can dim the lamp from 1 - 99% duty cycle, and the dimming is very linear. but, when i'm mesuring the voltage on the lamp with an osciloscope, i can see a peak of voltage (attacment 2). this peak consurnes me, becouse the final goal is to construct an AC-AC converter, to dim a 2 kW AC reflector. powered with 220V AC. there these peaks may occur much more stronger and fry the circuit.
so my first question is, how can I get rid of those peaks?
and the second thing, if you can give me a tip how to construct an AC-AC converter. I know that i have to use the IR2110. View attachment voltage on lamp.BMP
