simce
Full Member level 4
I've recently purchased a super cheap, most likely Russian IGBT based welding inverter named "Уралмаш Inverter MMA-300" that should be capable of delivering 300A, but the setting knob and value on display does not seem to be real (measured current with clamp shows significantly lower current than set value). Regardless of the fake specification that it can deliver 300A, i'd like to modify it to show real values on display so i'm sure i'm welding with proper currents, as much as possible with this type of device.
The board inside is marked to be: R-ZX7-100D-BQZKB-2
I'm wondering if there's anyone that might have a schematics of this device so i can analyze it and make a proper calibration?
Thanks,
Blagoj
Thanks,
Blagoj
