IGBT based FB converter Transformer choice
joemonraju
Newbie level 2
Newbie level 2
india
I am plaaning to make an IGBT based FB converter
the input voltage is 200Vdc, switching frequency is 38300Hz
I plan to use a transformer to step down this voltage to 50 V then rectify it with Bridge rectifier and give to a resistive load off 500 watts vide a step down chopper whose duty cycle can be controlled manually.
can anyone specify me a make for the transformer that i can use, preferably redily availble in the market.... I am new to hardware related works.... what should i say to the shop when i order the transformer.
also i am planning to use IGBT IKW75N60T
will it work with 200volt if so is it ok that I give 15 V dc as gate drive
