"if (x==1 && y==0)" in Matlab
davyzhu
Advanced Member level 1
oriental
Hello all,
How to do "if (x==1 && y==0)" in Matlab, the "if (x==1 && y==0)" is in C. Thanks!
Davy
hi,
see the matlab documentation..
u could see the matlab help for these sort of things.. or type "help if" in the command window and u would get it known from there...
nyways, the command is,
if ( a ==b & c ==d )
command........
end
also see here:
/http://www-ccs.ucsd.edu/matlab/techdoc/ref/if.html
/cedance
    davyzhu
In Matlab always use the help command it's a good tool to have!
help if
help &
This should help you in the future! As for you question.
if (x==1 & y==0);
That works
Peace
    davyzhu
it should be "if(x==1&y==0)"in matlab
davyzhu said:
Hello all,
Davy
If I were you, I would add extra round brackets
if ((x==1) & (y==0))
to be sure in order of operations. Also, it's much better readable.
