Chourizo
Junior Member level 2
![Junior Member level 2](/styles/images/ranks/clevel2.gif)
solution type
Hi to all,
I have readed that in the user guide:
1. Driven Modal - calculates the modal-based S-parameters. The S-matrix
solutions will be expressed in terms of the incident and reflected powers of
waveguide modes.
2. Driven Terminal - calculates the terminal-based S-parameters of multiconductor
transmission line ports. The S-matrix solutions will be expressed
in terms of terminal voltages and currents.
The, driven-terminal is for multiconductor systems?. All the antennas has a signal pin and a ground pin, so... when to use a driven-terminal solution?
If I have a dipole (1 conductor antenna), is the same using a driven modal and driven terminal solutions?
Hi to all,
waveguide modes.
