If base current is 100µA and current gain is 100, then collector current is?
ashokbly
Newbie
Newbie level 1
Choose the right one?
A. 1A
B. 10A
C. 1mA
D. 10mA
IF no, I will share your answer in the next post. Good Luck!!
<link removed by moderator - it didn't work anyway!>
Even if you don't know anything about electronics and BJTs the riddle can be solved:
You have
* Base current Ib = 100uA (unit: Amperes for current)
* gain= 100 (no unit)
And you want the result to be current => unit = Amperes.
Then there are just two possible mathematical operatiins:
* multiply
* divide
Because you can't add or subtract only values with identical unit.
Ampere - Ampere to get Ampere
or hours - hours to get hours
you can't subtract values with different units: you can't subtract Amperes from hours
But you can multiply and divide values woth different units: like Amperes x hours = Amperehours
Knowing this there are just two possible mathematical results ... whereas only one is in the given results to choose from.
Klaus
