thebadtall
Full Member level 6
Hello, I was looking for relays.
if a relay is rated 120vac 10 A can I use it for less amperes at 230v ?
thank you
thank you
His specification:
coil voltage 12v DC.
Relay Contact rating 120v 10A AC.
He is asking about relay contact.
It can able to switch 230v 5A AC supply.
Pls ask your question clearly...
I agree that you are possibly able to find a few relays on the market that are rated for 115 VAC but not for 230 VAC. They are mostly "signal" relays with 1 or 2 A current rating. I'm not aware of a 10 A type that switches 115 VAC and can't stand 230.there is a possibility
As per relays contact rating 120V 10A so it can capable to switch 1200VA. If you reduce the current and increase the voltage that is 230V 5A this also 1150 with in the limit of 1200 VA. So there is no doubt you can use it for upto 5A. If you have any doubt search for data sheet....
You can use the relay to any current less than rated contact, but if the contact voltage is increased the FLASH on the contact while it is breaking will increase (specially on Inductive loads) hence damaging the contact more rapidly as specified in the manufacturer's datasheet.Hello, I was looking for relays.
thank you
Sounds like a DC specification.it supports 250V at half amperes !!
