DO NOT try to measure continuity between IC legs, it proves nothing but could damage a good part.
You are reading it upside down Tony! It says Y9 not 6A. The crystal beside it is marked Y4. The manufacturer is using 'Y' as the designation for quartz crystals.If it is a gapped part, it is probably a polyfuse with 6A above it. I see these a lot.
I see no c r a c k.
