Identify those metal sheets that are easy to solder ?
loufoque
Junior Member level 1
Hi
I would like to identify those metal sheets that are easy to solder.
Those sheets of metal are thin, relatively rigid and easy to solder and sometime they have a shiny finish.
I have try to find these steel sheet with a tin coating but they are very hard to find here.
They use those metal sheet for making RF Shield for tuners and filters.
They are probably steel sheet, with a coating, but which one ?
Thanks for your help.
Gillis
Tinned steel is common, you can solder to bare mild steel
with decent surface prep (steel wool until bright, then get
it done before it re-oxidizes). I have done this many times,
even heavy gauge copper wiring to automotive firewall
sheet metal (with a high powered iron). It's all in the prep,
but the native steel is solderable.
I use it frequently. The steel sheet material I use has a tin coating/finish (tinplate). In the past I recycled tinned metal cans.
When you use old material (no longer shiny), you need to prepare it before soldering (use a sponge, scouring pad, or even steel wool as suggested by Dick). Sometimes I use a stronger water based flux for tinning large parts of thicker steel plate. Clean very well after using water soluble flux.
