Ideas for port scanning on dot matrix
rodros04
Junior Member level 1
I want to make an experiment about port scanning on dot matrix, but I have no Idea yet, Anyone can have I suggestion or Idea on Portscanning, I try to use the PicBasic and any Pic devices..., what specific IC i will use??? THANS A LOT
Re: DOT MATRIX
you could use something like this:
Re: DOT MATRIX
thank you..., but i will use the 5x7 dot matrix.., how to do a port scanning???
Re: DOT MATRIX
you, can use mc AT89cxx ,pic16f877 ,etc
for 40 columns and 8 rows
assume there is large data to display
scan loop2.........
scan loop1..........scan this upto your requirment = 20-30 times (not exact)
take first byte and place on row
then select first column line
small delay
clear the row data
take 2nd byte and place on row
then select 2nd column line
small delay
so on upto 40th column
scan loop1..............................................
after this increment the data pointer by 1
scan loop2..............................................
ok
but , it is just example , brightness of display also depends scanning speed .
enjoy
