Ideas/design about active biasing for ATF36077
abdoeng
Advanced Member level 2
ads user help me
i have serious problem wih ATF36077 ,condition of bias vds=1.5,ids=10 ma,
vgs=-.2,how??????,i obtain the vol of vgs,it was so small,also any buddy give me the wquastions of calculation of rs and rd
thanks so much
Re: ads user help me
Have a look at hxxp://www.applet.cz/~ulcak/lna.htm. (replace xx -> tt)
Bye
Mazz
hi mazz thanks for reply but i see tha site bofore if u have any paper about supply of atf36077 i will be thanked,how i get vgs=-.2 are u see it is impractical
if you realy need that value (very seriously), you may use 16bit D/A.
Use an active biasing scheme, it will fix the drain current and adapt the VGS to it's purpose!
any buddy have that design or ideas about biasing pls upload it or reply me at pm
regards
Put a 20 ohm resistor in series with the source lead to ground, DC ground the gate with an inductor, put 1.7 volts on the drain. Assuming a drain current of 10mA, the SOURCE to GROUND voltage is 0.2 volts AND thus the voltage from GATE to SOURCE is -0.2V (since the gate is grounded). The DRAIN to SOURCE voltage will be 1.5V (1.7V - 0.2V). Try it.
Check this out, too:
h**p://www.applet.cz/~ulcak/lna.htm
hi i avoid connect source to bias,here my design ,is that design correct,i apporximate that drain current equal source cuurent and gate ground voltage=-.2 plus voltage drop on source resistance
