Ideal Op amp differential in cadence
raju
Newbie level 6
Newbie level 6
cadence opamp
Is there an instance like ideal op amp in cadence?
cadence op amp
you can use the voltage controlled voltage source to get any gain with infinite bandwidth. If you want to select the bandwidth you can make a macromodel subcircuit with this as the input then a RC network to make a pole and follow that by another voltage controlled voltage source.
ideal opamp cadence
Thanks flatulent. In an ideal op amp the voltage at the +ve input and the -ve input will be same. Also there shld be no current flowing into the op amp. Is there anyway to model this?
thanks,
raju
ideal ampop cadence
This ideal voltage controlled voltage source has no input impedance. It just multiplies the voltage between two specified nodes without putting any further load on them. This function has a one line call and the part name begins with E. Look in the help file for more details or in a book on SPICE.
ideal opamp in cadence
I wanted to build a circuit similar to this in cadence. Is there a way like build this?
thanks[/img]
analoglib iopamp
The circuit is[/img]
ideal op amp
you can write a ideal opamp with AHDL/verilog-A in Cadence by yourself, or you can find it in a AHDL library which provided by cadence.
cadence op-amp design
I am looking for in Spectre. Any type of modelling with controlled sources is also ok.
thanks
cadence ideal
Raju,
AHDL also works with spectre.
Piao gave you the right suggestion
Labo
op amp design in cadence
VCVS instance in Cadence is what you are asking for. Check the manual for its parameters - besides simply multiplying the input voltage on the gain factor it's also possible model input and output resistance, -3dB point etc
cadence ideal op amp
Raju,
If u dont hav AHDL license then use 2 ideal voltage controlled voltage source to replace ur opamp.
E1 vinp gnd voutp vc <gain=10000> <-- check exact syntax
E2 gnd vinm vc gnd <gain=10000>
there will not be any i/p current consumtipm..and if u put ur opamp in negative FB confg, both the terminals will be short virtually..
cadence ahdl opamp
Hello, I am searching the same component in CADENCE (ideal opamp). What about the iopamp symbol which belongs to analoglib. Is this the model of an indeal Op Amp in Cadence?
Thank you very much for your answers and help.
operational amplifiers in cadence
Better construct your own idea op-amp using VCVS sources.. Refer to previous posts by members here..
Re: Ideal Op amp in cadence
i hope you still on this thread.
i search the opamp component too.
i try to use the [opamp] component from [ahdlLib] but haven't success to simulate it and just result some error.
the circuit:
4256337690
can you give me some advice?
one can go for using VCVS for designing model of opamp
---------- Post added at 12:02 ---------- Previous post was at 12:00 ----------
refer the analog mixed signal design by baker for more reference or brows LTspice schematics on CMOSEDU.com site
Re: cadence ideal op amp
Raju,
I have made this configuration, but when I design a voltage follower and put a pulse in the input I dont get anything in the output. Just a stable 0V signal. nothing changes. What's wrong?
