Tunelabguy
Full Member level 5
Most wall clocks run off a crystal oscillator running at 32768 Hz. But the frequency is not exact, so the clocks drift. Of course there are "atomic clocks" that lock to low-frequency radio station WWVB, and in the old days wall clocks locked to the AC power grid. But wouldn't it be nice to make any off-the-shelf wall clock that runs at 32768 Hz lock to a local frequency reference?
My idea is to generate a precise 32768 Hz signal and distribute it to the wall clocks. At each wall clock use the signal to excite a coil that radiates the 32768 Hz only a few inches. Place this coil as close as possible to the wall clock's oscillator, hopefully without even getting inside the clock or knowing anything specific about that clock (other than the fact than it is based on a 32768 Hz oscillator). If the clock's oscillator is already very close to 32768 Hz it should not take very much of an injected signal to make it actually lock to that signal. I wonder how hard it would be to get a clock oscillator to lock to the signal from the coil?
