IDDQ measurement doubt -- Please clarify
Nanda San
Junior Member level 2
Bangalore
Had a doubt.
With change in power supply requirements does the IDDQ results change? If yes, Why?
Regards,
Nandasan
Not an IDDQ expert, but if the voltage changes then the leakage current through the part would be different (V=IR). If the IDDQ test is automated, then perhaps the acceptable limits to detect problems would no longer be valid, leading to either undetected problems or non-problems being flagged.
Certainly every device's leakage will change, and a
"weak sister" may be exposed by higher voltage that
was "in the background" at lower. And dynamic current
goes, at minimum, as CVf.
