kdavid94588
Newbie level 6
Installed IC610 on RHEL4.
I have successfully installed IC5141 and it runs ok with my RHEL4. I tried to install IC610 because I wanted to use OA. I tried IC613 and IC614 but I don't have license files for these version.
Anyway, I ran license. Looks ok to me. Here is the log.
12:02:30 (lmgrd) US Patents 5,390,297 and 5,671,412.
12:02:30 (lmgrd) World Wide Web: **broken link removed**
12:02:30 (lmgrd) License file(s): /usr/local/IC610/share/license/license.dat
12:02:30 (lmgrd) lmgrd tcp-port 5280
12:02:30 (lmgrd) Starting vendor daemons ...
12:02:30 (cdslmd) FLEXnet Licensing version v10.8.2.1 build 30341
12:02:30 (lmgrd) Started cdslmd (internet tcp_port 33027 pid 6964)
12:02:30 (cdslmd) Server started on localhost.localdomain for: 12141
12:02:30 (cdslmd) 206 207 21060
12:02:30 (cdslmd) 21400 276 283
12:02:30 (cdslmd) 300 3000 3011
12:02:30 (cdslmd) 302 305 311
12:02:30 (cdslmd) 3111 32100 32101
12:02:30 (cdslmd) 32120 32125 32140
12:02:30 (cdslmd) 32150 32760 33301
12:02:30 (cdslmd) 34511 34530 365
12:02:30 (cdslmd) 4000 5100 570
12:02:30 (cdslmd) 70000 70110 71110
12:02:30 (cdslmd) 71120 71130 71510
12:02:30 (cdslmd) 71520 940 945
12:02:30 (cdslmd) 95100 95115 95120
12:02:30 (cdslmd) 95220 95255 95300
12:02:30 (cdslmd) 95310 95320 95400
12:02:30 (cdslmd) 972 974 TW01
12:02:30 (cdslmd) TW02 OASIS_RFDE Virtuoso_XL
12:02:30 (cdslmd) Virtuoso_Schem_Option Virtuoso_Turbo Virtuoso_Turbo_Basic
12:02:30 (cdslmd) OASIS_Simulation_Interface Corners_Analysis Substrate_Coupling_Analysis
12:02:30 (cdslmd) Affirma_AMS_distrib_processing virtuoso_chip_editor Virtuoso_Layout_Migrate
12:02:30 (cdslmd) AMS_environment Assura_DV_design_rule_checker Assura_DV_LVS_checker
12:02:30 (cdslmd) Assura_DV_parasitic_extractor Analog_Design_Environment_GXL Analog_Design_Environment_L
12:02:30 (cdslmd) Analog_Design_Environment_XL Virtuoso_Constraint_API Virtuoso_Layout_Suite_GXL
12:02:30 (cdslmd) Virtuoso_Layout_Suite_L Virtuoso_Layout_Suite_XL Virtuoso_Schematic_Editor_GXL
12:02:30 (cdslmd) Virtuoso_Schematic_Editor_L Virtuoso_Schematic_Editor_XL Virtuoso_Visual_Analysis_XL
12:02:30 (cdslmd)
12:02:30 (cdslmd) All FEATURE lines for cdslmd behave like INCREMENT lines
12:02:30 (cdslmd)
12:02:30 (lmgrd) cdslmd using TCP-port 33027
lmstat shows as below.
lmstat - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
Flexible License Manager status on Fri 2/11/2011 12:06
License server status: 5280@localhost.localdomain
License file(s) on localhost.localdomain: /usr/local/IC610/share/license/license.dat:
localhost.localdomain: license server UP (MASTER) v10.8
Vendor daemon status (on localhost.localdomain):
cdslmd: UP v10.8
Feature usage info:
Users of 12141: (Uncounted, node-locked)
Users of 974: (Uncounted, node-locked)
Users of TW01: (Uncounted, node-locked)
Users of TW02: (Uncounted, node-locked)
Users of OASIS_RFDE: (Uncounted, node-locked)
Users of Virtuoso_XL: (Uncounted, node-locked)
Users of Virtuoso_Schem_Option: (Uncounted, node-locked)
Users of Affirma_AMS_distrib_processing: (Uncounted, node-locked)
Users of virtuoso_chip_editor: (Uncounted, node-locked)
Users of Virtuoso_Layout_Migrate: (Uncounted, node-locked)
Users of AMS_environment: (Uncounted, node-locked)
Users of Assura_DV_design_rule_checker: (Uncounted, node-locked)
Users of Assura_DV_LVS_checker: (Uncounted, node-locked)
Users of Assura_DV_parasitic_extractor: (Uncounted, node-locked)
Users of Analog_Design_Environment_GXL: (Uncounted, node-locked)
Users of Analog_Design_Environment_L: (Uncounted, node-locked)
Users of Analog_Design_Environment_XL: (Uncounted, node-locked)
Users of Virtuoso_Constraint_API: (Uncounted, node-locked)
Users of Virtuoso_Layout_Suite_GXL: (Uncounted, node-locked)
Users of Virtuoso_Layout_Suite_L: (Uncounted, node-locked)
Users of Virtuoso_Layout_Suite_XL: (Uncounted, node-locked)
Users of Virtuoso_Schematic_Editor_GXL: (Uncounted, node-locked)
Users of Virtuoso_Schematic_Editor_L: (Uncounted, node-locked)
Users of Virtuoso_Schematic_Editor_XL: (Uncounted, node-locked)
Users of Virtuoso_Visual_Analysis_XL: (Uncounted, node-locked)
It looks to me license is running ok. But when I try to open a schematic inside CIW, I see these warnings and it doesn't open the schematic.
COPYRIGHT © 1992-2006 CADENCE DESIGN SYSTEMS INC. ALL RIGHTS RESERVED.
© 1992-2006 UNIX SYSTEMS Laboratories INC.,
Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program: @(#)$CDS: virtuoso.exe version 6.1.0 12/05/2006 13:23 (cicln05) $
Sub version: sub-version IC6.1.0.500.17 (32-bit addresses)
Loading geView.cxt
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_L
(deLicense-3) Could not get a license for Schematics L. Trying a higher-tiered license
*WARNING* (icLic-3) Could not get license Virtuoso_Schematic_Editor_XL
(deLicense-5) Could not get the license for Schematics. Open aborted.
Is this a license problem?
Here are what I tried so far.
1. Tried different license files.
2. Tried it with IC610_lnx86.ISR200612081658.
3. Tried it with RHEL5.
4. Tried it with RHEL5-64bit
5. Tried it with Ubunto10.10
All of them have the exactly same results. Here are my .cshrc and license setting.
license.dat
SERVER localhost.localdomain ANY 5280
DAEMON cdslmd $CDSDIR/tools/bin/cdslmd
I tried localhost. I also changed hostname and tried it.
.cshrc
setenv OA_HOME /usr/local/IC610/OpenAccess
setenv CDSDIR /usr/local/IC610
setenv CDS_ROOT /usr/local/IC610
setenv CDS_INST_DIR /usr/local/IC610
setenv CDS_INSTALL_DIR ${CDS_ROOT}/tools/dfII
setenv CDS_LIC_FILE ${CDS_ROOT}/share/license/license.dat
#setenv CDS_LIC_FILE 5280@localhost
setenv CDS_Netlisting_Mode Analog
#if ($?LM_LICENSE_FILE) then
# setenv LM_LICENSE_FILE ${CDS_LIC_FILE}:${LM_LICENSE_FILE}
#else
setenv LM_LICENSE_FILE ${CDS_ROOT}/share/license/license.dat
#endif
#setenv LD_ASSUME_KERNEL 2.6.9
#setenv LD_ASSUME_KERNEL 2.4.1
set capath=(${CDS_ROOT}/tools/bin ${CDS_ROOT}/tools/dfII/bin ${CDS_ROOT}/tools/plot/bin)
alias clic_start ${CDS_ROOT}/tools/bin/lmgrd -c ${LM_LICENSE_FILE} -l /tmp/cadence.log
As you can see I tried LD_ASSUME_KERNEL 2.4.1 and CDS_LIC_FILE 5280@localhost and still same results.
I have been googling almost a week and I din't find any solution.
12:02:30 (cdslmd)
12:02:30 (cdslmd)
cdslmd: UP v10.8
Feature usage info:
Loading geView.cxt
Loading LVS.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading schView.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ams.cxt
license.dat
.cshrc
#else
#endif
