IC5141 simulation result problem
qjt333
Newbie level 3
Newbie level 3
awd waveform blinking
I installed and ran the IC5141.
I made a schematic and simulated it using spectre.
And then, I checked simulation result using AWD window.
But graph's line flickered which was on and off.
I try to modify it but I can't solve it.
What is problem?
Do you get any errors or warnings in the CIW or the shell from where you started icfb?
If others grafic elemenst are not blinking I assume that a line property in the initial file have the property set to blinking. I think that the waveform could set 10 colors where you can set to each a property.
I confirm that others are not blinking.
If a line property in the initial file have the property set to blinking, what is method
which change a property?
Added after 4 minutes:
Yes. I didn't see any errors or warnings in the CIW or the shell(C-shell).
For reference, I installed it on CentOS 4.5.
Just a guess but it may be related with java.
Do you have Sun's Java or OpenJDK installed? You should use Sun's Java because OpenJDK can cause some problems.
I guess you will get many suggestions as this may be a rare problem.
I have seen cases of problems with java and sometimes also problems related with xorg/drivers and no errors whatsoever.
