byron
Member level 3
1) Is the USR1 necessary to be installed before installing the USR2, or only the base release is necessary.
2) I have installed IC5033 base and USR1, and try to install USR2. I start the softload and point to the path of the USR2, but it says the hierarchy of the USR2 is for IC50 not for IC5033, then the installation aborted. Does anyone have the same experience?
