ic5033 problem in fedora
sean202
Junior Member level 2
I installed ic5033 in RedHat8.0 successfully.
Now I am trying to install ic5033 in Fedora.
But there is an error message after I type in "icfb &" :
Incorrectly built binary which access errno or h_errno directly.
Needs to be fixed. :?
try set
LD_ASSUME_KERNEL=2.4.1
but it's work, isn't it.
It is not necessary for you to fix such problem. Just like what z81203 said, IC5033 is still working seamlessly.
@syncmaster
LD_ASSUME_KERNEL is used to resolve another more serious problem.
Yes, ic5033 works well though above mentioned message.
Thanks for your advice. :)
