IC50 PSS simulation problem
pengboy
Member level 1
Member level 1
I encountered something strange and I hope someone can help me here.
I just installed ic5.0 in redhat 8. Everything works fine until I try simulating pss using Spectre or SpectrS. I always get the following error, even for a very simple circuit which runs properly on IC50 installed on Solaris:
Internal error found in spectre during periodic steady state analysis `pss'.
Please run `getSpectreFiles' or send the netlist, the spectre log file,
the behavioral model files, and any other information that can help
identify the problem to support@cadence.com.
Assertion failed in file `hopss.c' at line 1313.
Assertion failed.
I guess it may be casued some Envirument Variable whichs is not set properly or maybe I need a OS patch for IC50 to run properly on RH80.
any one can run PSS analysis properly on RH7.3 or RH7.2?
