IC50 display errors: annot allocate colormap entry for ...
cougar168
Full Member level 1
Silicon Valley => Shanghai
I am using IC50 for LINUX.
When I start ICFB and use 8bit display, I got this strange error message in CIW
window:
Warning: Cannot allocate colormap entry for "#e0e0e0"
Warning: Cannot allocate colormap entry for "#800000"
Warning: Cannot allocate colormap entry for "#999999"
The color is distorted in any WINDOW (IC50) I open.
Does anyone know a fix for this?
TIA
Re: IC50 display problem
make sure your linux configure as 24-bits color
If you config your linux machine in 8bit color. The colour of application will affect each others.
Added after 26 seconds:
Cadence will only run in 8bit or 24bit colour mode. You can change the colour settings by changing it in the display option. You can also edit the file /etc/XF86Config-4 and change the colour settings there.
i met the same question before. Solution:
1.configure your display to 8 or 24 bits
2.update your display driver.
I met the same problem, i tried to use 8-bit color, and the diaplay is abnormal.
But when i changed my XF86Configure-4 settings to 24 bit, i even can not startx. What's the matter.
My display card is Intel 82845G Graphics Controller.
Any one can help, thanks!!
