mesfet
Full Member level 2
Hi all,
I encountered something strange and I would to like to ask if it is only my problems or not. I just installed ic5.0 in redhat 8. Everything works fine until I try simulating pss. I simulate the "lnasimple" as provided in "rfExamples" and there is error message pop up, "Internal error in spectre........", at the end of the simulation. I wonder have anyone countered this??
Command line:
spectre -env artist5.0.0 +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre0_2656_1 -format psfbin -raw ../psf \
input.scs
spectre pid = 2752
Loading /cadence/tools.lnx86/spectre/lib/cmi/2.0/libinfineon_sh.so ...
Loading /cadence/tools.lnx86/spectre/lib/cmi/2.0/libnortel_sh.so ...
Loading /cadence/tools.lnx86/spectre/lib/cmi/2.0/libphilips_sh.so ...
Loading /cadence/tools.lnx86/spectre/lib/cmi/2.0/libstmodels_sh.so ...
spectre (ver. 5.0.0.022703 -- 27 Feb 2003).
Simulating `input.scs' on localhost.localdomain at 10:59:44 AM, Fri Oct 31,
2003.
Warning from spectre during initial setup.
Q2: Parasitic resistor `re' has been deleted because its value of 50 mOhm (
R / (Area * MFactor) ) was smaller than `minr'.
Q3: Parasitic resistor `re' has been deleted because its value of 50 mOhm (
Circuit inventory:
nodes 11
equations 21
bjt 3
capacitor 5
port 2
quantity 6
resistor 8
vsource 1
Entering remote command mode using MPSC service (spectre, ipi, v0.0,
spectre0_2656_1, ).
Periodic Steady-State Analysis `pss': fund = 900 MHz
Important parameter values:
start = 0 s
outputstart = 0 s
stop = 1.11111 ns
period = 1.11111 ns
steadyratio = 1e-03
step = 1.11111 ps
maxstep = 11.1111 ps
ic = all
skipdc = no
reltol = 1e-03
abstol(I) = 1 pA
abstol(V) = 1 uV
temp = 27 C
tnom = 27 C
tempeffects = all
errpreset = moderate
method = gear2only
lteratio = 3.5
relref = alllocal
cmin = 0 F
gmin = 1 pS
pss: time = 28.43 ps (2.56 %), step = 6.687 ps (602 m%)
pss: time = 85.97 ps (7.74 %), step = 11.11 ps (1 %)
pss: time = 141.5 ps (12.7 %), step = 11.11 ps (1 %)
pss: time = 1.03 ns (92.7 %), step = 5.556 ps (500 m%)
pss: time = 1.085 ns (97.7 %), step = 5.556 ps (500 m%)
Conv norm = 5.64, max dV(net28) = 36.4735 uV, took 10 ms.
Internal error found in spectre during periodic steady state analysis `pss'.
Please run `getSpectreFiles' or send the netlist, the spectre log file,
the behavioral model files, and any other information that can help
identify the problem to support@cadence.com.
Assertion failed in file `hopss.c' at line 1313.
Assertion failed.
Command line:
input.scs
spectre pid = 2752
2003.
Circuit inventory:
nodes 11
equations 21
bjt 3
capacitor 5
port 2
quantity 6
resistor 8
vsource 1
spectre0_2656_1, ).
start = 0 s
outputstart = 0 s
stop = 1.11111 ns
period = 1.11111 ns
steadyratio = 1e-03
step = 1.11111 ps
ic = all
skipdc = no
reltol = 1e-03
abstol(I) = 1 pA
abstol(V) = 1 uV
temp = 27 C
tnom = 27 C
tempeffects = all
method = gear2only
lteratio = 3.5
relref = alllocal
cmin = 0 F
gmin = 1 pS
Assertion failed.
