hqqh
Full Member level 4
ic5 crashes under suse82
- i have installed ic_5 under suse8_2.
- i created a schematic and start the analog design environment to simulate the circuit with spectre.
- then i setup the stimuli and when i setup the analysis methode and click ok, then the entire icfb is closing and in the terminal window the error message "Speicherzugriffsverletzung (memory access error)" appears.
Has anyone the same problem or are there any suggestions what the reason of this problem is?
thanks in advance,
hqqh
thanks in advance,
hqqh
