IC5.0 Skill Development error
maolh
Member level 2
Member level 2
I am using IC5.0 on Linux 7.3. Everything seems fine until it tells me no license to run Skill Development. Is there any special license configuration for Skill Development? The composer of schematic, virtuoso layout, and Analog enviroment work very well. So is it really a wrong license problem? Could you guys give me a working license for Skill Development?
Thanks in advance.
I forgot to tell you, the license line for Skill Development is like the following:
FEATURE skillDev cdslmd 5.600 permanent uncounted 1C8E44ABAB8C8E2BF232 HOSTID=ANY
FEATURE skillDev cdslmd 96.040 permanent uncounted 7C1F54848D828AC4830B HOSTID=ANY
I have a problem with Analog Artist.
When I intend to make a simulation , only "Add Simulation' is visible. Others such "delete , disable , edit" are not visible. They are shadowed.
Second problem with models. When I convert spectreS models ( for instance NPNLower ) Cadence doesn't recognize models..it's very strange.
In fact , I'm very sure that I show the path of models correctly. Therefore I can not simulate active components.
Any idea ?
