IC with zillions of pin in O*Cad?
bluecube
Member level 1
Member level 1
How do you folks handle IC with over couple hundred pins with Orcad Capture? do you split the IC into multiple section and called UxA, UxB? but how would you combine all of them into a single package for PCB layout? is there a command to tell Orcad layout that U1A, U1B is the same chip but different section?
