IC with quad transistors
bio_man
Full Member level 2
Full Member level 2
I am looking for an IC that has quad MOSFET transistors (or higher) with all terminals available for external connection.
Something like: ALD210808, but here the body is always connected to source. I want the body to be also connected to an external pin.
Thanks
Thanks
Hello,
Toshiba in their portfolio has many IC with transistors arrays - see link:
https://toshiba.semicon-storage.com/ap-en/semiconductor/product/linear-ics/transistor-arrays.html
https://pl.mouser.com/c/?marcom=179038666
Maybe you will be able to find among them such that met your needs.
Best Regards
    bio_man
thanks and I appreciate your help, looks like these are gate drivers.
I want to build some current sources and buffers in transistor level circuits. I want to confirm the results using ready made transistors, I don't want to take the IC layout route at this stage. It's just a proof of concept. Few of my transistors require connection for the body
--- Updated ---
btw, single transistors can be an option but I have many transistors leading to more sophisticated setup
As I know true 4 terminal discrete MOS doesn't exist, bulk is always hidden. I have tried to find one without success. Below link shows not you and me are the only ones tried.
    bio_man
