Rhine
Newbie level 3
Need Help.Can any one tell me any Ic which can work as relay.I'm the manufacturer of power supply , we use 12v 5pin relay in "Battery Backup Power Supply" for switching.Normally Relay takes some seconds for switching which is ok for camera.But not for Fire Control and Access Systems.Some how we found solution by replacing relay with Doide.But problem comes when load is given, the diode drops charging current whereas relay don't do this.Therefor i need any ic which can work similarly to 12v Relay for fast switching.
