i urgently need circuit for an ic tester. It should be able to test IC 74xx series(i.e and , or , not etc). A microprocessor based circuit will be more useful.
Here is the tool which you are looking based on pic micro and you can add
chip your own altough its come with lot of chip lib built in but you can edit and add more chip when you want just check out this topic
