IC replacements, MPPT by Tim Nolan.
myfaithnka
Full Member level 1
Hi all,
I am trying to to do Tim Nolan MPPT prototype,the problem I face is that the IC IR2104 is not available for me,so I am trying to find another mosfet driver.
Can anyone suggest me commonly available Mosfet Driver
thanks
How about the IR2110? It's similar and is commonly available. Go through the datasheet for the pin configuration and specifications.
Hello tahmid,
this is Tim Nolans MPPT circuit I am trying to understand,
IR2104 block diagram,
IR2110 block diagram,
Can they be used if I do the following
feeding Hin and Lin same signal but invertor gate in front of Lin.
Or will it can be tackled in code some how ?
thanks
Yes you should be able to use IR2110 instead of IR2104.
I assume you're not using the Arduino Due. If so, supply the IR2110 VDD with 5V.
Hi tahmid,
Sorry for not replying,I had to hold my mppt project,I am using arduino uno.
So I have to connect HIN and LIN.
Vdd to solar panel plus,Vss to solar panel negetive.
What about other pins ?
