IC for temperature measuring with precision of 0.2 degrees C
tranki
Spain
I need a schematics or info about IC or other system for measure temperatures with a precision of 0.2 degrees C
termistor kty10
You can use LM92 from national or Dallas/maxim DS18B20
+/-0.5C
ds18b20 outdoor accuracy
use one transistor and 12 bit adc but calibration is very hard.
<font size=-1>[ This Message was edited by: ebenni on 2002-02-25 02:51 ]</font>
a way to measure temperature
The best choice is the National LM92 (±0.33°C Accurate, 12-Bit). You can reach it at **broken link removed**
or a LM35 at
Iampic
application cd4538
Try the Nat Semi LM35DZ. gives an output of 10mV per degree 'c'. Connect 10k resistor from output to ground will increase accuracy..
cd4538 schematic
The dallas device works great and you can chain them.
It is possible to add calibrationcurve to get better than the published accuracy.
c source temp sensor pdf
I'm not sure if this would help
but for circuit temperature monitoring you could use a ref02 which has a 2mV/Deg C temp coefficent.
how a plc measures temperature
At the company where I am working we use KTY10 resistors and a PIC16F877 to do this.
We developed a way that does not need any calibration ...
regards
kty10 source code
I can't believe that you don't use any kind of calibration!?
kty10-5
I meant you do not need to calibrate the circuit, all you need to do is set the temperature of the sensor once.
This will store an offset value in EEPROM and as long as you do not change the sensor everything will be OK.
regards
i2c lm92
I used NTC thermistor, RTD, Dallas 1820, LM35, KTY10. The easiest to use was Dallas 1820. Anyway, ALL of them need calibration.
dallas ds18 visual basic example
To: Tranki
which temperature do you want to measure in which range.
What kind ouf output you like to get.
lm92 circuit
To: c-man
That's what people call calibration.
greetings
theremistor
You Can use SMT160 Temp Sensor with pulse output you must measure pulse duration ,many source exist for doing that if you search on https://www.av.com.
shematic circuite smt160
I recommend radiometric or bridge platinum schematic + sigma-delta ADC (Analog Devices, Crystal). You have exellent stability + accuracy
thermistor kty10
Tranki what range of temperature are you going to measure? Room temperature? Outdoor temperature? Hot water? Sub zero?
Some components and design perform differently or not at all if they use components that cannot cope with the temperature range you need the circuit for. Since you are looking for a very thight accuracy, you have to consider the rest of the circuit as well, not just the measuring sensor. Resistors change their value with temperature, as do capacitors. But this is not widely recognised by all designers.
Aare you also going to measure the temperature with a seperate probe, or do you want to use the component (i.e. LM35) as the probe? All these factors are important in your final design.
ntc thermistor 0.1c
You could always use a thermistor plus resistor if you don't need high accuracy or else use an LM335
interface adc0801 lm35
But the best way will probably to go with an LM92 which has a i2c interface
kty10 application note
Well, I need measure air conditioned installations.
The range of temperatures is about -30ºC to +40ºC. The reason of precission is the problem. I find many information on IC's and schematic circuits for temperature measure, but I need a precision of 0.2ºC because the system uses diferential temperature between ambient and flow air conditioned temperature.
Thanks!
