ic aompiler instlation problem
mohamed.hagag
Member level 1
Member level 1
Egypt
Captureeeee.PNGi have this problem and iam sure i scl is in good case
if you know English than you should understand tar archive is corrupted.
can't understand
what should i do?
i re download from another link and the problem is the same .
this problem appear before the last problem
I wonder why you are trying to install it in your home directory?
my target to run IC compiler not any thing
ok
what do u think should i make the director?
first you must to check if that Linux can be used with that software ...
