[SOLVED] IC 616: ADE-XL 1921 error
unix_amr
Junior Member level 1
Dear all researchers and students;
I am trying to simulate a simple memory circuit. But when I simulate the circuit in virtuoso ADE XL , I face this error:
{ (ADE-XL 1921): Failed to start new job after 3 attempts: Possible reasons could be:
1- The machine selected in the current job setup policy is not reachable.
2- The cadence hierarchy in not detected, not installed properly or not compatible on the machine selected in the current job setup policy.
3- Job Start script /home/username/project/.temp_username/.cmddir0/runICRP2 is not found on the remote machine.}
The screenshot of this error is also attached to the post. Furthermore, the installed version of Cadence and machnie is as follows: IC616 & MMSIM151 on Ubuntu 16.04-64bit
Thanks for your attention
Dear Dominik
According to your suggested method, I installed the said fonts in the mentioned directory, and my problem was addressed. Thanks again.
