ic 5033 installation error
hqqh
Full Member level 4
Full Member level 4
to type fontstruct ic5033
i try to install ic5033 under suse9.1. I have set LD_ASSUME_KERNEL=2.4.1. i have read the most post to the topic of ic5 installation and i did it under suse8.2 successfully but now there is a strange problem.
when i start with icfb the program comes up and in the ciw the following messages appear:
8-bit PseudoColor Visual is not available (default Visual option).
\o Using 24-bit TrueColor Visual.
\o The program xdpyinfo can be used to verify the Visuals available
\o for your display.
\o Loading PRshare.cxt
\o Loading LVS.cxt
\o Loading acv.cxt
\o Loading auCore.cxt
\o Loading schView.cxt
\o Loading selectSv.cxt
\o Loading seismic.cxt
\p >
\o Warning: Cannot convert string "-adobe-helvetica-medium-r-normal--0-100-75-75-p-0-iso8859-1" to type FontStruct
\o *Error* getqq: argument #1 should be a symbol (type template = "sS") - (cdba.data)
\o Loading Skill files for skillCore
\o *WARNING* (autoloads): skillCore.cxt was not loaded
\o *Error* load: can't access file - "startup.il"
\o ******* Non-recoverable error (no top-level or error handler)
\o ******* Exiting program ...
can someone help me?
greetings,
hqqh
Maybe the problem is in your system. You can try to install it in RH7.3.
Hello,
I too have the sane problem. And when I try to edit a cell in layoutplus, no layers are displayed. Any suggestions.
The display is 16bit or 8bit ,you can change you
display to 16bit at /etc/X11/XF86config file.
Try to change variable LANG
Good luck.
the filename is correct, but you have to set the display to 24bit. right? just set everything in this file into 24bit, if you don't care other situation.
thanks for all answers, but i have already tried to set the lang as well as the assume_kernel-variables and the color depth is set to 24 bit.
i have no idea what the problem is. maybe the file system? i think i use reiser fs.
any ideas?
greetings,
hqqh
