pgr2002
Member level 5
- Joined
- Aug 1, 2013
- Messages
- 87
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Hyderabad, India
- Activity points
- 2,015
The above circuit is "Simple Micro Ampere Meter Circuit" convert & help in measuring small currents in five ranges: from 1 µA to 10 mA. . For example if a 1 mA meter is used, the total resistance (the sum of the resistor R and the coil resistance Ri of the meter) must be 1kΩ. If a 100 µA meter is used, the total resistance must be 100 kΩ. If needed, a potentiometer can be used for the R.
Now the problem lies in getting the IC3130. Can we use LM741 or any other Op-Amp IC instead of 3130? Any other ideas regarding this circuit for further modifications.
