ankitgarg0312
Full Member level 2
i read from some appnotes that ibis V-I curves contains tables of voltage and current
this voltage column for pullup is
vtable = vcc - vout
is above correct?
if yes, how does ibis specify when pullup or pulldown will work ( on what input voltage levels pullup/pulldown will be switched on)
V-T curves are extracted at which slew at input?
if slew changes how will output be calculated by simulator??
please help , i am breaking my head on understanding ibis files......
vtable = vcc - vout
is above correct?
