IAR AVR C, Low/High byte of INT variable
Diamant
Newbie level 6
Newbie level 6
Need access to bytes of integer (16 bit).
I can do this in case if I know the integer address:
char *variable1 = (char*) 0xXXX; (address of integer)
char *variable2 = (char*) 0xXXX+1; (address+1 of integer)
is there any other way?
char *variable1=(char*) IntVariable; -could not be compiled
Moving integer left/right to receive Low/High byte is not god idea for me.
...Need help of advanced programmer...
The better is to do it via union
typedef struct chara
char char1;
char char2;
} chars ;
typedef union tall
int16 intn ;
chars charn;
} mynumber;
mynumber tnum1.intn = 65535;
char first_byte = tnum1.charn.char1;
char second_byte = tnum1.charn.char2;
What about this:
union
int integer;
unsigned char bytes[2];
}variable;
variable.integer to access it as an integer
variable.byte[0] and variable.byte[1] to access it bytewise
hope this is useful for you
Sorry for my post repeating artems answer, I could not see it while I typed this :)
Thanks a lot, this is the perfect way out!!!
I forgot about unions...
off: going to read more about unions.
debug has been successfull, thanks again
Or about this:
int integer;
char byteHi, byteLo;
byteHi = integer / 256;
byteLo = integer % 256
or
byteHi = integer >> 8;
byteLo = integer;
Eskimo, this code needs additionals variables in memory to be created, I havent got them at all
